Help w/ wiring on "battery in the rear"
Old Mar 22, 2005 | 12:57 PM
  #16
1-bad-z28's Avatar
Re: Help w/ wiring on "battery in the rear"
Originally Posted by csmonte
I belive NHRA wants you to run a separate wire from the Alt back so you can cut the alternator power also, incase of any problems.
The NHRA rules say you have to have a power cut off switch. You don't have to run a wire from the alt. to the battery.
You don't want a lot of current running through that factory distribution block. With the resistance of the longer wires and all the current being pulled right there at that one spot, it could get hot and maybe start a fire. If you are not grounding the battery, you are not completing the circuit. You have to run a wire from the negitive on the battery to the chasis.
Old Mar 22, 2005 | 12:59 PM
  #17
1-bad-z28's Avatar
1SlowFormula....you beat me to the punch. I'm a slow typer.
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Zomie
Sep 2, 2002 09:04 PM
$hawn
Aug 17, 2002 04:37 PM
