Help tracking down TPS problem (pinout?)
Old May 30, 2008 | 05:04 PM
tim95z28's Avatar
Hi, I have a TPS sensor fault, and I went ahead and got a new one, still the same code.
I checked, and am getting the 5v reference voltage and the ground looks good. That make me think that the wire that carries the signal back to the pcm is damaged. I cannot figure out which wire it is going into the pcm...several wires with the same color.
Any ideas on how to trace this wire back to the pcm or troubleshoot this problem would be appreciated. This is a track only car, and drives pretty good on road courses at speed. At lower rpms it doesnt run so well..and will hardly idle .big cam but I think the tps sensor problem is adding to the problem.
Tim
Old May 30, 2008 | 05:10 PM
Shoebox has the wiring diagrams for the 95 LT1 on his website. The TPS sensor is shown on page "pcm1"
http://shbox.com/1/4th_gen_tech2.html#1995_pcm_wiring
Old May 31, 2008 | 08:29 AM
tim95z28's Avatar
Thanks Injuneer and Shoebox, I'm going to go out and try to track it down!
Tim
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Feffman
Oct 9, 2015 05:42 AM
edman
Jan 22, 2015 02:45 PM
