help oil in t/b and intake
Old May 28, 2009 | 10:11 PM
sick9lt1's Avatar
ok guys i am new to the site and have a problem, my car smokes out of the exshaust but it is verry little at idle and gets worse wot. i took off the intake and seen there was what looked like oil in the t/b so i rubed my finger in there and it was wet blck stuff. so help what could the problem be. thanks in advance.
Old May 28, 2009 | 10:18 PM
Slick_Sammy's Avatar
how many miles on it? web black stuff is not necessarily oil. does it smell like oil, maybe it's just grime. is there perhaps a crack or other way dirty air could get past your filter (check bottom of intake eblow). what kind of smoke comes out exhaust-- black or white? how may miles on car? or specifically how many miles on valvetrain?
Old May 28, 2009 | 10:34 PM
sick9lt1's Avatar
no there is no crack and there are maybe 10,000 miles on the rebuild. stock bottom end, but it dose smell like oil i was reading about this alot on here and i have found that the hose out of the intake side is full of oil so could it be the pcv valve. i think the smosk is a like dark color but i will look again. i am lost cause the car rund good and i went and had it dyno'd and it put down 322whp and 346 wt but at the end of the dynoit was smoking on the rev down but not wot.
Old May 29, 2009 | 12:11 AM
porksoda's Avatar
Check the hose that runs from the passenger side valve cover to the TB. I can guarantee it is filled with oil and that is where it's coming from.
Old May 29, 2009 | 09:17 AM
sick9lt1's Avatar
yes that hose is full of oil will that cause it to burn oil ams smoak a lil bit
Old May 29, 2009 | 07:35 PM
Starting a new thread to ask what the PCV valve looks like wasn't a good idea. Why not continue the topic in this thread, so people will see what answers you already have, and the history of the problem?
https://www.camaroz28.com/forums/sho...d.php?t=690330
Old May 30, 2009 | 08:09 PM
sick9lt1's Avatar
ok i want to thank all the guys that helped me with this, and the update is that i put in a new pcv valve and cleaned the t/b like you all said. then i took it for a spin and the smoke went away no more smoke wot. thanks alot
Old May 30, 2009 | 08:43 PM
ACE1252's Avatar
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
