what dose the pcv look like
Old May 29, 2009 | 03:31 PM
sick9lt1's Avatar
ok i went to change the pcv valve and the one the auto parts store sold me was not the same. the one on the car is black and it is see through. the new one has like something in when you shake it you can here it. whats the diff and will i be ok with the one that i got from the auto parts store.
Old May 29, 2009 | 03:50 PM
The stock one is silver metal and yes, you can hear it rattle when you shake it. I don't know what the heck you had on there before.
Old May 29, 2009 | 04:21 PM
sick9lt1's Avatar
so i am good now with the one i got from the autoparts store. and i hope it will stop the smoke problem i have.
Old May 29, 2009 | 04:41 PM
madhatter's Avatar
You sure you pulled the PCV valve and not the elbow?
The PCV valve is on the left(driver) side of the intake manifold in the center. Many people pull the black breather elbow on the passenger side valve cover thinking it is the PCV valve.
Old May 29, 2009 | 06:14 PM
Robwhartlt1's Avatar
I pulled the black elbo out of the pass side. There is nothing ealse there or on the drivers side. And I have drove it today will I mess something up.
Old May 29, 2009 | 07:21 PM
Shoebox has a photo of the location of the PCV valve on the driver's side of the intake manifold.
http://shbox.com/1/pcv.jpg
On your 93, it will be different. 93/94 there is a U-shaped elbow that connects the end of the PCV valve to the vacuum nipple about 3" behind it on the manifold. 95-97 has a hose that runs to the front of the intake manifold. You can see the 93/94 setup in this photo of my engine:
http://www.injuneer.com/images/photo.../dOptivac1.jpg
The line on the passenger side of the intake, that runs from the throttle body to the valve cover, supplies the filtered air that the PCV system vacuum pulls down through the oil passage in the head, through the crankcase to pick up blowby, then up through the lifter valley to the bottom of the intake manifold, where it is pulled out through the PCV valve.
If you've read similar posts, you should have picked up the fact that if you have excessive ring blowby in the crankcase, or you have a non-functioning PCV valve, pressure will build in the crankcase, and the vapor will push up through the hose on the passenger side, picking up oil droplets along the way, and enter the throttle body, pooling oil in the top of the throttle body, under the cover. It will then drip down in front of the throttle blades, and enter the intake manifold, causing the black sludge.
A small accumulation of oil in the system is normal, over a long period of time. If you get a lot of oil, you have a problem with blowby, or the PCV system is not working. The presence of smoke would indicate a similar problem.
Old May 29, 2009 | 07:44 PM
sick9lt1's Avatar
ok so like i ask will it mess something up and can i drive it home. i did take the black elbow out and my dumb *** put in a pcv on the passenger side. will this hurt or not. i dont want to mess the car up
Old May 29, 2009 | 09:47 PM
It won't "mess the car up". But it would be a good idea to put the elbow back in the valve cover, and put the PCV valve in the correct location on the driver's side of the manifold soon.
Old Jun 14, 2009 | 05:32 PM
SSTAT's Avatar
Sorry to hijack - if the grommet where the black elbow goes in the passenger side valve cover is worn/loose - would this contribute to the vacuum leak that causes high idle?
Old Jun 14, 2009 | 09:38 PM
To check, pull the elbow out and plug up the hole in the valve cover. See if the idle changes?
A vacuum leak has to be fairly severe to cause high idle. A small leak will simply cause the PCM to close the IAC valve down and reduce flow through the idle air passage. Once the IAC valve is fully closed however ("0" counts), the engine will idle higher than spec due to a vacuum leak. You can check the IAC valve commanded position with an OBD-II scanner. That will tell you if the valve is fully closed and unable to control the idle.
drt
Sep 27, 2015 04:39 PM
surreybrad
Aug 10, 2015 09:34 AM
mavricki18
May 21, 2003 02:02 AM
xxsaint69x
Apr 28, 2003 09:27 PM
RedNose
Apr 9, 2003 04:52 PM
