HELP.....MSD 8.5mm wires
Old May 8, 2005 | 09:07 PM
OneFreakZ's Avatar
Has anybody heard about MSD wires not fitting for a 94 Camaro Z28 i got the wires for that appllication i went to take my car to the shop to do the tune up and my mechanic told me the wires wont fit behind the power steering pulley where the wire looms are he refuse to put them on so if any body has them on the same appllication OR know a different wiring route please let me know or any suggestions i really want to put those wires on...thanks
Old May 8, 2005 | 09:21 PM
rpm4lalo's Avatar
Re: HELP.....MSD 8.5mm wires
If you have the correct MSD's for a 94 lt1 then I would find a different mechanic.
Old May 8, 2005 | 09:59 PM
transamtom's Avatar
You need to remove the stock 7mm wire loom holders,and use cable ties to secure them.
It is kind of tight,sounds like he is frustrated and wants more money for the job.
Old May 8, 2005 | 10:32 PM
RicocheT's Avatar
I got them to fit, its tight behind the pully and a wire tie is needed to make sure they don't hit, but all of mine fit fine in basically the stock locations
Old May 8, 2005 | 10:59 PM
Compstall's Avatar
No, the size probably has nothing to do with it. Your mechanic probably took one look at the routing and realized how much fun it would be to change the wires and knows better. LOL
TitoPR221
May 26, 2015 12:20 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Don 97 SS
Jul 11, 2005 08:50 AM
RedLineRev
Jan 23, 2003 03:51 PM
kandied91z
Aug 6, 2002 01:18 AM
