Problem with Eagle H beams
I just bought some eagle H beam rods that are suppose to be weight matched. Ofcourse they're not tho, from lightest to heavy I have a 3 gram difference. They are suppose to matched within 1 gram. Anybody else have this problem?? I'm gonna contact Eagle On Monday and see if they will weigh out a set and exchange them. They look to damn good to grind on with a dremel.Also bought a Eagle forged crank. The rear seal surface (1 piece seal) doesn't look as smooth as the factory crank. Are you suppose to put a chrome sleeve over it?
Re: Problem with Eagle H beams
I dont buy or use eagle products for exactly that reason - I have seen too much crap from them that customers bring in because they bought it from summit.
You should be able to run your fingernail over the seal surface and not chatter...very smooth.
