Help me shave off 4 tenths so I can run 12.000!
Old Sep 23, 2003 | 03:48 PM
JeremyKweens's Avatar
currently with my setup I ran a 12.488 @ 113
Mods are:
K&N cold air
mac crank pulley
tb bypass
taylor OVC wires
jacobs coil
autolite 104s
mac headers and y
custom 3" catback with cutout
100 NX shot
the reason I only want to shave 4 or so tenths is becuase I dont want to install a roll cage.
Old Sep 23, 2003 | 03:50 PM
oh, and I dont want to bump up to a 150 shot....yet.
Old Sep 23, 2003 | 03:56 PM
GhostZ's Avatar
!AC
!Spare tire/jack
!Back seat
Skinnies
What were your short times?
Old Sep 23, 2003 | 04:00 PM
my 60fts??
there are anywhere from 2.1 - 1.97s with Et streets (bad traction and im taking it easy on my rear end)
Old Sep 23, 2003 | 04:09 PM
Sweetred95ta's Avatar
I'd put a 160* in your car, the cooler it is, the better it runs. Have you thought about any suspension mods? Do a couple of those, and you could be running the time you want.
Benji
Old Sep 23, 2003 | 04:16 PM
Teal94Z's Avatar
a few more suspension mods, and maybe some longtubes should get ya there....any weight reduction wouldn't hurt either
Old Sep 23, 2003 | 04:17 PM
93Z286Speed's Avatar
LCAs and Subframe connectors cant hurt thats for sure, and the loss of weight obviously wont hurt you. I dunno if you thought of gears? i dunno what shifter you have but that can make a difference like Stock vs. Pro 5.0
Old Sep 23, 2003 | 04:28 PM
Spinner's Avatar
ignore me, your a manual...
Old Sep 23, 2003 | 04:38 PM
I was thiking about doing lcas and subframe connectors. I still have the stock shifter and im not to sure about gears.
Old Sep 23, 2003 | 04:42 PM
Javier97Z28's Avatar
Moderator
If you insist on being easier on your rear you're just gonna have to jet up .
Cut a good 60' and you're in the 11's.
Old Sep 23, 2003 | 05:16 PM
jchevy's Avatar
Running that high of a MPH with the stock cam you probably dont want to do gears, you are gunna run out of RPM in 4th gear and have to hit 5th.
Old Sep 23, 2003 | 06:35 PM
funina91ss's Avatar
12 bolt/9" tell me how you are leaving in it now?If you could pull a 1.7X I think that would get you were you want to be. or swap the M6 for a A4 and not worroy about the rear. I am beating on my 10 bolt pretty hard with 1.605 60ft times.. man that fells so good with a 3.23 gear
PCLZ28
Dec 24, 2015 05:19 PM
slothgrant
Aug 22, 2002 03:01 PM
vic_wants_an_SS
Jul 30, 2002 11:38 AM
STS-Formula
Jul 26, 2002 01:35 PM
