Help me pick some heads
Old Sep 8, 2010 | 08:20 PM
amean94ta's Avatar
the ones i have now Lloyd elliot did 5 years ago they are 95 lt1 castings
he gutted them and did one of his most extreme port jobs ever. they are welded and smoothed really great heads but i had them shaved to 50cc
back then i was going for a high compression all effort motor its a 398 ci lt1 and has 14.5:1 compression with my heads cause the pistons are .005 out of the hole
so what bare castings would you reccomend me for 93 octane? has a solid roller cam in the high 600's, th400, moser spooled 9" with 4.30 gears.
i have been out of the loop for a few years and lost track of whats new and or working good
Old Sep 9, 2010 | 06:24 AM
hvyss's Avatar
That's an easy one. Call Advanced Induction. I used LE2's for several years. Best N/A was 12.41@109. Built a 385 stroker this spring with AI 200cc heads, cam, and intake. The car has picked up almost a second N/A. Ran a best Of 11.53@116 at the LTX shootout and came in runner up in Extreme Street N/A. And using a smaller cam on the AI setup.
Old Sep 9, 2010 | 05:32 PM
If the heads are "really great".... why not change the pistons to drop the CR?
What is the dynamic compression ration (DCR)? That's what determines the fuel octane requirement, and that's what you need to figure to get the correct piston dish.
Old Sep 9, 2010 | 08:19 PM
RamAir95TA's Avatar
+2 on the AI setup. AI heads hold all of the records. It only makes sense.
Old Sep 10, 2010 | 11:35 AM
RealQuick's Avatar
What is the goal for the car (maybe I missed it in the first post)?
AI and LE both have great results. I picked LE because of how I was treated when dealing with him... 4th set of heads being sent to him for work.
Old Sep 13, 2010 | 03:07 PM
amean94ta's Avatar
it was a drag car i drove on the street (i made it that way) i want to add the power stearing back, ditch the weld draglites and get some nice 18's, run 93 octane and take to car shows and cruises.
i'll have to figure out the dcr
Old Sep 13, 2010 | 04:37 PM
funina91ss's Avatar
If you just wanting something to cruise around the car shows in you might be better off keep the heads you have.
What are your power goals?
Old Sep 13, 2010 | 10:57 PM
amean94ta's Avatar
cant they are shaved and get me a 14.5:1 compression ratio. i wanna run 93. anyway guess i have all winter to think and or buy a set. i want atleast mid 11's i do want the car to be somewhat quick still
Old Sep 15, 2010 | 08:08 PM
zzoomin's Avatar
have llyod hog out some of TF's new 21* heads!
Old Sep 15, 2010 | 08:17 PM
z275plus's Avatar
What about the trick flow heads?
Old Sep 15, 2010 | 11:23 PM
amean94ta's Avatar
new 21 degree heads? see its things like this i dont know are new i wanna really research all this before i make my decision
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
pimpss96
Feb 12, 2015 01:28 PM
Chris Anderson
Jan 27, 2015 08:30 AM
95chwagon
Jan 13, 2015 09:19 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
