Help Me! Codes, Maf! Please
Old Jun 26, 2004 | 02:21 PM
Mr_Superman's Avatar
Ok so heres the thing, a long time ago I descreened my MAF, and well anyway did plugs wires, and all that fun stuff, start my car idles weird for a sec then idles normally, check engine light comes on. Itsd throwing two codes 48 which is something about the downshift of 3-2? And the second code was 84 meaning Mass Air Flow System Failure...where do I start? What to do???
94 Z by the way
Old Jun 26, 2004 | 04:59 PM
You have the codes backwards.
48 Mass Air Flow (MAF) sensor circuit
84 Skip shift solenoid circuit (manual transmission) or
3-2 Control Solenoid Circuit (automatic transmission)
You neglected to say if you have a 4L60E or T56.
I would start by checking the pink wire on your MAF for 12v when the key is ON. Check fuses, too, if needed.
Old Jun 26, 2004 | 05:54 PM
Its a T56, but it was originally an auto. As for the codes all is well, no more check engine, I had a wire break off on the MAF and it wasnt making connection. As for the shift problem I guess its where the tranny has been switched.
Side note: Thanks for the response shoebox, you seem to be one of the geniuses on the board and I appreciate your response and eagerness to help. As for my car its ok now. Thanks again shoebox
Old Jun 26, 2004 | 07:03 PM
Genius? Nah, I just know how to click the "post reply" button.
Dzmaro
May 7, 2015 09:33 AM
lt1matt
Mar 21, 2015 07:35 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
