Help !!!Keep Burning Plug wires
Old Feb 19, 2003 | 04:47 PM
zizux's Avatar
I just installed a new set of taylor wires sunday and one is burnt and sparking to the headers.
I routed them a dif way this time but they are just to close I guess. Is there anything I can put over them to help keep them from burning?
Old Feb 19, 2003 | 05:03 PM
RamAir95TA's Avatar
Taylor makes heat-treated fiberglass boots that are safe to over 1000 degrees. Thunder Racing carries them...
Or you can go ape with zip-ties, or use an over-the-valve cover setup like many of us are opting for.
Old Feb 19, 2003 | 05:18 PM
94_formula's Avatar
any chance you have a pic of that?
Old Feb 19, 2003 | 05:23 PM
RamAir95TA's Avatar
Surely.
http://www.worldisround.com/photos/347/157.jpg
http://www.worldisround.com/photos/347/158.jpg
I'm not using the boots though, because with the MACs, it is physically impossible to burn the wires (or pinch them) with the way I have routed them.
Old Feb 19, 2003 | 05:33 PM
12sec97Z28's Avatar
I'm guessing it's the number 6 wire huh? had the same thing happen to my msd superconductors with my edelbrock headers. Here's how I remedied it. It's kind of expensive, but it works well. Over a year with no problems now. Accel makes shorty plugs to work with these cars, and they give you about 1/4-1/2 inch more clearance. Doesn't sound like much, but it makes a big difference. I also had to ditch the MSD wires and went with Accel Extreme 9000 wires. They have a heat reflective boot, and they are very good wires. The most important thing I did is route the number 6 wire around the back of the oil dipstick to keep it off the header primary. It makes the wire a tight fit to reach the distributor, but it will reach, and you won't have any more problems.
Old Feb 19, 2003 | 05:35 PM
12sec97Z28's Avatar
I could be wrong, but with edelbrock TES on a dual cat car, I don't think it's possible to go over the valve covers. the way the headers are shaped, they don't leave enough room to run the wires up on the driver side. The TES for single cat cars has no problem because they are shaped very differently.
Old Feb 19, 2003 | 09:01 PM
Bud M's Avatar
I used Accel 9000s too and have had no problems. For #6 I used the longest wire in the set and routed it so that it went past the plug and then looped around back up to it which routed the wire no closer than about an inch from the pipe.
Old Feb 20, 2003 | 09:21 AM
Crystal Baller's Avatar
I burnt several wires even with some heat resistant covers over them. I went over the valve covers after that on 2 of the wires and it's been great.
Old Feb 20, 2003 | 09:37 AM
Smoke T/A's Avatar
Time to go with a set of over the valve cover wires. They will be the last set you ever buy.
Old Feb 20, 2003 | 09:55 AM
zizux's Avatar
LMFAO they are OVC wires. but cause my car is a duel cat car I have a funky drivers side header.
BTW I now have mac's but they cooked the wires just as fast.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
