help install A/F guage
Old Aug 21, 2004 | 08:54 PM
Zrag's Avatar
I just bought a autometer air/fuel guage w/out instructions can anyone scan one for me or tell me how this goes hooked up?
thx
Old Aug 21, 2004 | 10:49 PM
1msfyter's Avatar
Re: help install A/F guage
Very simple. Tap into the purple wire under the hood leading to the passenger side 02 sensor. Ground is easy and for power i tapped into the stereo lead or you can plug into the fuse bolck radio or any switched power.
Old Aug 21, 2004 | 11:02 PM
All the AutoMeter instructions are available online:
http://hp.autometer.com/instruction_...tions/837j.pdf
You can go to pins C8 and C20 in the gray PCM connector and choose either the purple, or purple/white wire, depending on which side sensor you want to monitor. You could add a single-pole/double-throw (SPDT) switch and be able to choose which sensor to display.
Splice into the vehicle harness wiring, NOT into the sensor wires.
When you get all done, you will have a bunch of LED's that flash back and forth, and are mainly annoying. When you go WOT, it will simply show "rich", and the sensors aren't accurate enough at WOT to tell you any more than that.
Old Aug 22, 2004 | 09:13 AM
Zrag's Avatar
Thanks Guys!
Nov 18, 2023 07:21 PM
warmeck
Apr 27, 2015 04:34 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
