Want to do 1.6 RR's but need some help, Please
Old Aug 20, 2004 | 06:14 PM
OnefstCamaroZ28's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
Ok. I just got seme 1.6 Self-Aligning Roller Rockers. I hear so much about different springs. What springs should I get? Also what else is good to do when I got the valve covers off, like pushrods, valves, etc. Please let me know. Thanks a lot
Old Aug 20, 2004 | 06:52 PM
)2overt SS's Avatar
Re: Want to do 1.6 RR's but need some help, Please
I don't know what other people did... but all I did was take out the old rockers and put in the new ones. I kept my stock springs, pushrods etc.. everything works fine.
Since we have 96's I believe we recieved hardend pushrods from the factory (unless I'm confused with something else) And I don't see why we can't use the stock springs... so unless you have something wrong with your pushrods that would pose a reason to change etc... I'd just leave everything.
Old Aug 20, 2004 | 08:29 PM
do you know if like better pushrods will give u better power
Old Aug 20, 2004 | 08:36 PM
toneloc12345's Avatar
Most people get LT4 springs when they put the 1.6rr's in.
TONY
Old Aug 20, 2004 | 08:40 PM
indieaz's Avatar
With a stock cam there's a good chance you'd be fine. Although as long as you're at it I'd definitely buy some insurance with some stouter springs.
All pushrods do is open and close the valves. Hardened ones won't give you more power. The only way you can get more power is if your pushrods are the wrong length and your valvtrain geometry is off. You won't have this problem becuase yours is stock. It would probalby be wise to take them out and do the glass roll test to check for straightness...again more insurance and it's a simple thing to do while you have the rockers off. Simply find a flat surface (mirror works good) and roll them on it. If they are bent get new ones becuase they are super cheap. All a hardened pushrod is going to do for you is stand up to more stress without bending. With a stock cam it shouldn't be necessary. If you find yourself replacing them anyways then get hardened ones becuase there is no point in saving a couple pennies for a cheap component that could potentially screw up your engine.
Old Aug 20, 2004 | 08:44 PM
LT4 springs..........where can I get them...
Also any benefit from going with different pushrods and valves. I have the stock heads though..
Old Aug 20, 2004 | 08:56 PM
indieaz's Avatar
you can get LT4 springs from the dealer. I believe thunder racing has them and summit.
New valves aren't necessary unless the existing ones are worn. Beyond that it's a question of how much you want to spend. We good go on all day - but if you are going to replace the valves it's probably worth going to a machien shop to have them do it and while they are at it do a valve cut back and valve job - they will also bake the heads which will get rid of carbon deposits. This is a pretty simple and inexpensive thing to do and probably wortht he money. My valve job and cut back ran around $120-140 or so.
As for different pushrods i covered that in my previous post
Old Aug 20, 2004 | 09:05 PM
Thats cool. I just noticed you have a B4C too. So I should just get LT4 springs, and leave it at that, for a simple yet effective, but not too drastic upgrade?
Thanks for the replys
Old Aug 20, 2004 | 09:11 PM
Pasky's Avatar
I got some lt4 springs, brand new I never used them when I bought my 1.6 RR's. Thier still sealed in the gmpartsdirect bag. I bought a CC306 so I don't need them anymore. $25 + shipping and thier yours. Just PM if your interested.
Old Aug 20, 2004 | 11:36 PM
Alright so im gunna get the LT4 springs. What else is needed to complete this project, sumthin like valve spring compressor or sumthin???????
Old Aug 20, 2004 | 11:43 PM
Lt1t56's Avatar
I used my Crane Gold 1.6 for 100,000 miles with no problems with stock springs, however did change out for better springs when I had the heads off for reconditioning due to a blown head gasket.
Old Aug 20, 2004 | 11:56 PM
indieaz's Avatar
Yes you will need a valve spring compressor. Should be able to pick one up at pep boys/autozone.
Old Aug 21, 2004 | 10:54 PM
Alrighty.....Ok how do I change the springs without the valves falling in? I dont want to use a air compressor cause thats a pita, and the one i have dosent work for more than 2 minutes. so there has god to be a different way to do it....anyone know??
Does anyone have like a guide to install RR's and springs
Old Aug 22, 2004 | 09:14 AM
80TA's Avatar
There is a way to find tdc and then move the engine around in 90 degree steps and do them .You should find exact way.Compressor is pain in lt1 since spark plug access is awful unless you have headers.Rope in cylinders is another way but again you have to take out plugs.I did the 90 degree thing in my ls1 and it worked fine.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
