Help with codes please.
Old Jul 11, 2004 | 02:58 PM
97WRAITH's Avatar
I scanned the car with datamaster last night becasue I still have a part throttle miss/stumble I can't figure out.The ses light is NOT on.Here are the codes I got.
MALF13-Left o2 fail
MALF 48-Malf system fail
MALF66- A/c press sensor open/short
Can some one explain this it looks straight forward just want some feed back.Thanks!
Rob.
Old Jul 11, 2004 | 03:53 PM
I guess you are OBD-I converted?
Just to be sure, you might clear the codes and see if they all return. You might have burned O2 wires, a poor power connection to the MAF (fairly common-check the pink wire for 12v with the key ON), poor connection/wiring to the a/c sensor or bad sensor.
As always, check fuses.
Old Jul 11, 2004 | 04:02 PM
97WRAITH's Avatar
Yes OBD1 converted. Sorry forgot to mention that the a/c is removed but I have never gotten that code before.I'll clear the codes and check fuses.Did you mean to check for power to maf sensor? Thanks Shoebox.
Rob.
Old Jul 11, 2004 | 04:07 PM
944v8inDFW's Avatar
Just an FYI If you use Tuner from CATS you can disable all the AC codes very easily.
Old Jul 12, 2004 | 08:58 PM
97WRAITH's Avatar
Well did some checking and it seems like I have this stumble miss problem after the car warms up.When its cold it runs fine.Opti maybe?
hix5000
21
Jun 16, 2015 11:52 AM
browenb
Parts Wanted
May 7, 2015 09:50 AM
95chwagon
Parts Wanted
Feb 28, 2015 12:12 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
