Help build my LT1 (going in faster than planned)
Old Mar 30, 2009 | 01:10 PM
  #31
bombebomb's Avatar
Originally Posted by 19~Camaro~90
Well i figured i can get them for not that much money and i know thats what makes the power. Do you think if i get them heads i could go with the cc306? Or would i need to get the whole computer tuned?
thanks
kevin
You should get your computer tuned even if you get a cc503/hotcam/etc.
Old Mar 30, 2009 | 05:51 PM
  #32
19~Camaro~90's Avatar
Look iv said this a few times that i will be getting headers and already have a exshaust. I forund some ported LT1 heads with 2.02/1.6 vales for 250+shipping so i thought that would be a good thing to buy. Then i wanted to know if i get the heads should i go with a bigger cam? If so please tell some? I heard alot about the 306cc? I have the harness and the computer it is complete and it came with the motor. How much would a tune cost? Iv been told around 500? Getting it looked through is a good idea i will try and talk to them about that.
thanks
kevin
Old Mar 30, 2009 | 06:01 PM
  #33
'94 Bad A Z28's Avatar
Around $500 for a full dyno tune, but you can get a mail order tune for something like $100-$125.
Old Mar 30, 2009 | 06:44 PM
  #34
Whats a mail oreder tune? Is it like a chip or something?
kevin
Old Apr 1, 2009 | 03:00 PM
  #35
Iv been looking at a few cams off comp cams web site and a few said needs computer tuning? Can i get a mail order tune or do it have to be all redone?
thanks
kevin
Old Apr 1, 2009 | 04:32 PM
  #36
reamo04's Avatar
read through this
http://www.superchevy.com/technical/...des/index.html
its a caprice that they built. Show what the different mods gained in ET and MPH
also, a mail order tune, you send in your computer, they put the new tune on it, and sent it to you.
With any cam, you NEED a tune, otherwise you run a risk of damaging your motor. You will also more than likely need new fuel injectors.
I suggest before you do anything, you go through several thread of people upgrading. I know about a year and a half ago on here (maybe longer than that now) there was a COMPLETE list of everything you would need for a cam swap
Old Apr 1, 2009 | 07:00 PM
  #37
Where do you guys send in your computers to get tuned?
Then i am going with this set up!
Rebuild kit
headers/ y pipe
3000 stall
tune computer
then if i get them heads the 306cc if not the 503cc
Dose anyone have anything that they would change?
thanks
kevin
Old Apr 1, 2009 | 07:53 PM
  #38
reamo04's Avatar
Rebuild kit
headers/ y pipe
3000 stall
tune computer
thanks
kevin
remember, with the cam you are going to NEED
springs, pushrods, locs, retainers, new rocker arms, and im sure theres more that i am missing
i sent mine to pcmforless.com bryan herter is a very stand up guy, and if you have datamaster and can datalog it, you can send him the datalogs and he will correct the tune as needed.
Old Apr 1, 2009 | 08:04 PM
  #39
Yes i know i would like to find a hole kit instead of buying everything individually. Ok then thats where i will try!
thanks alot
kevin
Old Apr 5, 2009 | 06:52 AM
  #40
about to buy this cam? what you think he said it was between the 305cc and the 306cc. Then all this to.
Comp Cams Pro Magnum 1.6 Roller Rockers(NSA) with Poly Locking nuts
7/16" screw in studs
Guide plates
hardened pushrods
have a nice cam for the LT1 for sale 230/236 HR113. Lift is 0.544/0.554 with 1.6 rockers. Its inbetween the CC305 and the CC306.
I think it will be good?
thanks
kevin
parkers Z28
Mar 11, 2016 08:14 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jrlt1
Jan 3, 2015 07:38 PM
ModdedNerd
Dec 10, 2014 08:42 PM
