Help with AFR rev kit!
Old Jul 5, 2003 | 02:59 AM
  #16
bunker's Avatar
Thanx man I really hope so if anyone else knows about this I'd appreciate that since I'm putting all this in, I don't want to hurt performance in any way, this is to improve it a bit & give me safety
any other input I'd greately appreciate thanx guys.
Old Jul 5, 2003 | 03:45 AM
  #17
rskrause's Avatar
Moderator
Originally posted by Shawn 97 Z28 M6
I think you'll have to use the 6150 kit. The bodies are the same between the stock and comp R's, but I think the top surface is different. I know when I say Jordon's kit on a Turbo'd 383, his used some black alignment keys - and he has Comp R's for lifters. I'm using stock lifters w/ the factory alignment keys and 16 little "nubs" that rest on top of the lifter body.
But, I have some comp R's on order as this HE grind cam is floating my valves at about 6k. <- It's the only thing I have left to change! LOL.
Sounds like maybe a spring issue, not lifters. What spring are you using?
Rich Krause
Old Jul 5, 2003 | 05:50 PM
  #18
bunker's Avatar
TTT
I wanna know for sure.
Old Jul 5, 2003 | 11:07 PM
  #19
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
Rich Krause
Not too sure.. But they measure around 145lbs on the seat right now. Some double coil w/ a dampner that Seth at Combination Motorsprts hooked me up with. However I did dyno today and it seems my fuel pump is taking a dive - 14.2:1 a/f @ 6000rpms.. So I'm going to install a new fuel pump and see if that helps some. At 2k I'm running around 11:1 a/f, it just leans out as RPM's increase (by about 25psi according to my FP gauge).
Old Jul 5, 2003 | 11:58 PM
  #20
97 RedSS's Avatar
Your FP drop at WOT Shawn?
Cody
Old Jul 6, 2003 | 01:28 AM
  #21
93formula's Avatar
This is bunker, stop hi-jacking my thread!!!
Old Jul 6, 2003 | 09:07 AM
  #22
Cody
Yeah... Stock FP though, so I guess it's to be expected.
Old Jul 6, 2003 | 06:01 PM
  #23
bunker's Avatar
Seriously this sucks, I wanna know.
Old Jul 6, 2003 | 06:13 PM
  #24
97 WS6 T/A Conv's Avatar
bunker,
I was over at GMRULZ house today (he's doing heads and cam too). We pulled his stock lifters and compared those to the Comp R's........the body of the R lifter is practically IDENTICLE to the stock lifter body. The Rev kit springs rest on the lifter body, you are good to go.
Old Jul 6, 2003 | 08:19 PM
  #25
GMRULZ's Avatar
Originally posted by 97 WS6 T/A Conv
bunker,
Yep, body of the lifter looks identical to me. I put the 2 side by side and could see no difference. The only diff is a little preload built into the comp R`s. One thing also since there is preload built in never tighten your lash more than a 1/8th of a turn past zero, do not treat these lifters like stock lifters when setting the lash. 1/16 to an 1/8th past zero and you will be straight. More than that and you will have premature failure of comp R`s. FYI.
Good luck
Old Jul 7, 2003 | 12:39 AM
  #26
bunker's Avatar
Thanx guys, yeah I saw that post but it wasn't 100% answer thanx guys
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
