heads cam on 90K
Old Mar 25, 2004 | 09:36 PM
  #16
97WS6SCharged's Avatar
Originally posted by bow94z
What would a Valve & spring job run about? what exacxtly do they do when porting and polishing heads.....something i might want to consider doing i would like to restore power bak into my 122k LT1. funds are kinda low too
As far as price, my 3 angle valve job was about $200, but I reused the stock valves. New springs, locks, retainers, and seals were about $90 (these are my light weight stocker heads, so I didn't spend much money on them, now my other set of heads are a different story, they are starting to look killer). So you should probably figure on spending about $300-400 total for a good valve job depending on if you get new valves or not. If you want a port job, they usually run about $600 for an econo port, and over $1k for a full race port. When they port and polish, they generally open up the ports, blend the passages for smoother flow, and do a bit of reshaping work on the chamber.
Old Mar 25, 2004 | 09:55 PM
  #17
Bow94z's Avatar
thanks 97ws6charged!, think its worth the time and money to do it? just to do a valve job.
mikey4play
Mar 15, 2015 11:45 AM
armedtrigger
Feb 24, 2015 08:30 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Rich_z28
Aug 27, 2002 12:20 AM
