Heads and cam
Old Oct 30, 2020 | 08:53 PM
PonchoDude's Avatar
Heads and cam
Seriously considering doing heads and cam from Loyd Elliot along with long tubes in the future.What other things should I consider to go along with the new set up?
Old Oct 31, 2020 | 04:21 PM
Chimera96's Avatar
Re: Heads and cam
You will need a PCM tune. Depending on how big the cam is (read anything more than a "mild" cam) larger injectors, 30 lb, Headers.
The torque converter is directly related to engine power so a higher stall TC and then lower rear gears to take advantage of the increased power the motor makes
Basically its a domino effect when you start performance molding. To get the best out of the motor...you need to improve the components downstream of it to get the potential the engine can produce
Old Oct 31, 2020 | 05:58 PM
Re: Heads and cam
In addition to above, consider a 52mm or 58mm throttle body depending on HP. Over 425 HP at the flywheel, multiply HP times 0.07 to get minimum injector size - no real problem with oversized injectors within reason - consider a 255 LPH fuel pump. Once you go over ~450 HP, the 10-bolt rear axle may need to be replaced if you run sticky tires on a prepped track. An adjustable torque arm and LCA relocation brackets may be useful.
Old Oct 31, 2020 | 07:17 PM
PonchoDude's Avatar
Re: Heads and cam
I already have 3.73 gears and a 2800 stall converter. I guess posting on a mobile device doesn’t let my signature show up. So I should upgrade the fuel pump and injectors. What about valve train upgrades? What size injectors? I definitely plan on porting the intake and going 58 mm throttle body.
Old Oct 31, 2020 | 07:51 PM
Re: Heads and cam
Your signature is visible, and I saw it. Whether the stall is high enough depends on the cam..... where it builds strong torque. We don’t know what level you're looking at for the heads or the cam. Lloyd has a fairly wide variety of options. That's why I qualified all my points in somewhat indeterminate terms. Throttle body, fuel pump, injectors, rear axle depend on HP level.
Interesting you seized on the throttle body..... I have a 58mm TB, LT4 intake opened up to 58mm, and the shop that assembled and tuned the engine showed me, on an engine dyno, that the 58mm was overkill at 500 flywheel HP. Bach calculating, a 52mm TB would have been adequate. They still laugh at my 58mm TB.
Old Oct 31, 2020 | 09:29 PM
PonchoDude's Avatar
Re: Heads and cam
Sounds like a 52 mm TB is all I’ll need. All very good information thank you. I’ve owned this car for 23 years and have never been to serious about upgrading the power level. Honestly I’ve never had a lot of extra money to spend on it. I’ve nickel and dimed the current mods that are on the car. I can now afford to start doing things to the car that I’ve always wanted to do. I’m leaning towards LE -2 heads with the 226/232 cam.
bym
May 4, 2018 08:38 PM
Pipsovich
Jul 23, 2017 05:33 PM
GravesZ28
Feb 16, 2017 04:09 PM
Eric94GT
Sep 15, 2014 05:23 AM
summer nights
Jul 31, 2011 05:55 PM
