more power
Old Jul 31, 2011 | 01:40 PM
summer nights's Avatar
more power
Hello every one, got hooked up against a new mustang last week,great race and in the end i took him by a half a fender, he ended up with a smoking engine and i ended up with a knock in my 95 z .Im looking to rebuild and add approx 100 more horses with out nos..any ideas?Planning to upgrade to 2.02 1.60 valves , better springs and maybe more compression,input on cams ?will need some programming also..thanks for the help.
Old Jul 31, 2011 | 02:27 PM
boostedz28lt1's Avatar
Re: more power
A nice top end with a matched cam will net you some more power, but you will need to put it to the ground. Rear control arms gears and a stall will help
Old Jul 31, 2011 | 04:34 PM
Re: more power
Have your stock heads ported, with a matching cam. Add required valve train upgrades, good set of headers, larger injectors, larger throttle body, a good computer tune and you are well past +100HP. Two sources for the heads/cam:
http://www.elliottsportworks.com/
http://www.advancedinduction.com/LTX/AiLTxMain.php
Old Jul 31, 2011 | 05:55 PM
MTL_Z28's Avatar
Re: more power
Exactly this.
Stock with a SLP Cold air intake my car put down 245 RWHP. Then using the list that injuneer just gave you I put down the numbers in my sig. so +95 HP. And that was with a small port job on stock heads and budget cam kit with off the shelf cam. You can do much better with Heads from Lloyd or AI and a custom cam.
However as boostedz28 pointed out, the new power will be useless if you can't put it to the ground so also plan for some suspension mods and better tires if you haven't already.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
NewsBot
May 16, 2015 03:40 PM
XtremeLt1
Sep 13, 2002 08:50 PM
