headers - coated or uncoated?
Re: headers - coated or uncoated?
"looks" is the least important of the advantages offered by the cera-metallic coatings:
-reduced stress cracking and corrosion
-reduced under hood heat
-increased exhaust scavenging
Jet Hot claims up to 3% HP gains, but who believes a manufacturer's HP claims?
I like my Kook's stainless steel LT's.
Stainless steel won't rust, crack, or need to be re-coated. I haven't compared them to any other LT1's with headers as far as heat goes, but the engine bay IS quite warmer than with stock manifolds.
I noticed a huge difference in under hood temps after I got my LPE stainless shorties coated. And everything seems to cool down faster under there. They look great, too, but I was more concerned with keeping the heat where it belongs...inside the headers...
--Alan
--Alan
Definitely get them coated. I went with the Hooker LTs uncoated cuz hell I live in NC I didn't think rust would be a big problem. Wrong! I had them on for a month and noticed rust already forming on them. It's around $200 for the coating, but now that I have had the oppurtunity to have them uncoated, I highly recommend you go with coated headers. If you have the money Kooks is the best way to go.
The therory that stainless steel will not rust is not true. It depends on the grade of stainless steel. 409 stainless ( which most headers are made of) WILL RUST not as bad as alloy steel but they will rust. The only stainless that will not rust instutional grade stainless such as 304,316,318 etc. So just because the headers are stainless steel does not mean they will never rust.
HVY SS
HVY SS
There will be a surface temperature reduction with a header tube that has been internally and externally coated with a cera-metallic coating. Whether that temperature reduction is enough to avoid toasting a wire that is touching it is doubtful. But directionally, it will reduce the potential for damage to wires and other components that are not actually touching the header tube.... just "close". There's been more than a few heater boxes melted by uncoated headers.
For those that are interested. I have coated hookers on mine and my friend has uncoated on his 72 Chevelle with a built 327. There is nearly a 200 degree difference between them where mine is lower.
carguyshu
Jan 22, 2017 11:19 AM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
