Header gasket
Old May 9, 2014 | 08:56 PM
  #16
Chet1185's Avatar
Re: Header gasket
So first startup with the copper gaskets. Both side leak pretty bad. Do these need to be heat cycled to tighten them?
Sent from my LG-LS860 using Tapatalk
Old May 10, 2014 | 07:19 AM
  #17
Re: Header gasket
Did you check the header flanges for being straight?
Old May 10, 2014 | 11:49 AM
  #18
Chet1185's Avatar
Re: Header gasket
I just installed the gaskets that came with the headers and its leak free. They were Klinger Thermoseal gaskets.
Old May 10, 2014 | 05:13 PM
  #19
Chimera96's Avatar
Re: Header gasket
FWIW I never had luck with "copper" header gaskets even with quality headers and new heads.
If the ones you put on that came with them hold up, great. If they burn out...My $02 is FelPro 1470
Old May 10, 2014 | 06:18 PM
  #20
Chet1185's Avatar
Re: Header gasket
Yes, everyone suggest the felpros. If these blow out ill change to those. Long tubes are sooooo much easier to change stuff then shorties.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
