Head/intake swap... remove fluids??
Old Jun 29, 2007 | 03:41 PM
95z28man's Avatar
Is it necessary to drain any fluids for a head/intake, no cam swap?
Old Jun 29, 2007 | 03:44 PM
sssalah's Avatar
The coolant needs draining.
Old Jun 29, 2007 | 03:47 PM
95z28man's Avatar
Thanks, is that all? The only reason I ask is because fluids are the only issue I have with working on my car at home since it tends to get messy sometimes especially if I screw up and spill something.
Old Jun 30, 2007 | 09:26 PM
red67camaro's Avatar
Yep, only the coolant. However if you drain it using only the radiator drain, the coolant will only drain as far down as the water pump ports leaving quite a bit in the block which will spill as you remove the lower head bolts and the heads. Also drain the block using the block drains. On an LT1, these will be the knock sensor on the right side and a corresponding plug on the driver's side.
Old Jun 30, 2007 | 09:30 PM
SS RRR's Avatar
And if you want both banks drained then you must pull both plugs.
I'm just lazy though. I have a drip pan (almost covers the entire area of the engine) and just let the coolant drain from removing the head bolts.
warmeck
Aug 24, 2024 08:05 PM
Fatdog2
Apr 27, 2015 10:32 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
lt1matt
Mar 21, 2015 07:35 PM
alex5366
Feb 17, 2015 10:43 PM
