Having probs w/ Plugs or Wires
Old Oct 26, 2003 | 02:12 AM
unTAmedLS1's Avatar
So heres my problem when its dark I can see that the spark is actually grounding on the head and not the spark plug. Also when the car has been running for a while and gets to operating temp the wires are arcing on eachother. These are on fairly new msds. I have a set of taylors waiting to go on because I havent had any luck with the msds but what I am mostly concerned with is the fact that even the new taylors are arcing into the head instead of the plug....what causes this? Oh yeah actually the driverside has taylors on it and the pass side has the msds
Old Oct 26, 2003 | 06:16 AM
SWINGRRR's Avatar
Maybe some cracked porcelin on the plugs if it is grounding on the head. They just do that sometimes. I use NGK TR55's and have had no problems. Well, beside the Jet Hot LT's cooking the wires.
I would replace the plugs also.
Old Oct 26, 2003 | 10:23 AM
unTAmedLS1's Avatar
yeah I also have jet hot lts and ngk plugs...I figured out a way to zip tie everything away from the headers though so that there is about 2 inches of clearance on each wire...I only had probs with the driverside wires gettin fried before I did it
Old Oct 26, 2003 | 10:47 AM
gb95zconv's Avatar
Make sure your grounds are clean at the ICM , coil and ground strap......also use dielectric grease on the boots if you havnt. If you have allready used the grease make sure you didnt get it on the metal contact points.
Old Oct 26, 2003 | 01:50 PM
unTAmedLS1's Avatar
I thought dielectric grease is suppose to go on the contact points...is that what its for?
Old Oct 26, 2003 | 02:51 PM
gb95zconv's Avatar
No .....it goes on the rubber boot ....its nonconductive and is suppose to help prevent arcing. Clean it off and try again.
PCLZ28
Dec 24, 2015 05:19 PM
charchri4
Apr 14, 2015 06:40 PM
eanhl2004
Apr 4, 2015 12:01 PM
IRABuss
Sep 7, 2011 09:08 PM
gh0st
Sep 1, 2002 10:24 AM
