Harmonic Balancer Hole Location not 120 degrees?
Old Apr 18, 2005 | 06:55 AM
matt65's Avatar
Does anyone know why GM went to the trouble of making the spacing of the holes on the Harmonic Balancer, and it's mating hub NOT 120 degrees?
I ask because the under drive pulley that I have recently tried to install had holes evenly spaced at 120 degrees, making the installation impossible.
I searched other threads for this information, attach link if this has already been discussed.
Old Apr 18, 2005 | 08:06 AM
Re: Harmonic Balancer Hole Location not 120 degrees?
Since the hub and pulley are two pieces, they likely did it so they could only be mated one way. This maintains phasing of the timing pointers and any balancing that might have been done at the factory. Not sure how knowing why they did it is going to help.
Old Apr 18, 2005 | 09:36 AM
matt65's Avatar
Yeah,
The question of why was asked to satisfy my curiosity.
Are all LT1's Like this? I know that some balancers/Pulley require a 3-jaw puller, while some have threads to use a harmonic balancer puller.
I had ordered a pulley that was evenly spaced out at 120 degrees, of course it did not fit.
Old Apr 18, 2005 | 11:26 AM
As far as I know, all the harmonic dampers are the same, with the "offset" mounting holes. Both the damper and the hub have TDC markings.
The puller "technically" isn't required.... its just the rust that builds up over the years that make it necessary. Its actually a "loose fit" when new... I changed mine out for an ASP damper/UD pulley when the car was only a couple months old, and the damper literally fell off the hub when I got the three bolts off.
Old Apr 18, 2005 | 12:27 PM
Originally Posted by matt65
Yeah,
There is an early and late model style of pulley like you describe.
eanhl2004
Apr 4, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
cyteone
Feb 7, 2015 06:04 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
smokin5s
Jul 24, 2003 10:47 PM
