guys with MAC headers - what kind of cat are you running?
Old Oct 13, 2004 | 12:45 PM
kertong's Avatar
And what exactly are the measurements?
I ran a MAC hiflow cat (single) in my setup, but it didn't quite align/fit right and I had exhaust leaks hissing up the wazoo.
Now I'm about to look into getting a cheapie catco, but I want to be SURE it'll line up right so that it won't leak.
What kinds of cats work well for you guys? I haev a mandrel bent i-pipe which I'm sure is aftermarket (no crinkles), and lokos about 2.75" in diameter..
and where can I get some cheap cats? Is it easily weldable by a shop to the MAC headers?
Old Oct 13, 2004 | 12:50 PM
stereomandan's Avatar
Re: guys with MAC headers - what kind of cat are you running?
http://www.camaross.com/forums/showt...highlight=make
Is your cat welded into place right now? The MAC Y-pipe should have a male ball/flange connector at the back, and the intermediate pipe should have a female ball/flange connection. If that is the case, you can make one like I did. I did find cheaper ball/flange connectors at www.drgas.com
Dan
Old Oct 13, 2004 | 12:59 PM
kertong's Avatar
thanks, stereoman dan!
Nope, its just bolted right in, because the MAC hiflows come with the ball flange in back already. I still have the ball/flange connector somewhere in my closet - but if i can't find it, any exhaust shop should be able to fabricate it, right?
anyway, thanks for the help.
Old Oct 13, 2004 | 05:06 PM
Fastbird93's Avatar
I'm running the Mac Cat and haven't had any problems with it!
Old Oct 13, 2004 | 05:19 PM
Bersaglieri's Avatar
I have a 3" Catco if you want one. I was going to use it on the Z, but it just sounded to damn good to tame. PM me.
-Dustin-
Old Oct 13, 2004 | 05:25 PM
1995greenTA's Avatar
im running the stock cat. just gutted, i was sort of dissapointed with my macs...i had to take and get a new peice welded onto my stock cat, and then bolted that to the y pipe...
Old Oct 13, 2004 | 05:45 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I just had an exhaust shop gut the cat, then run a straight pipe through. The look of a cat without the restriction.
Old Oct 13, 2004 | 05:47 PM
Kataklysm's Avatar
I'm running some aftermarket cat welded upto a pipe coming off the y and welded to the "s" pipe. I believe its a 3 inch.
Old Oct 13, 2004 | 07:12 PM
12SCNDZ's Avatar
When I first installed my MAC's, I used one of their "Off-Road" pipes with my cut-out welded in it...I never had any leaks with it. Then when emissions time rolled around, I had a cat made the same length and identically flanged on each end as my ORP. Neither leak, and I can swap them in about 20 minutes. This arrangement makes it nice because I was able to buy a cheap $70 3" cat. Flow isn't really important because it never stays on the car very long.
Frank
CobraEatr
Jul 24, 2004 11:37 AM
mysticslp2002
Jul 29, 2002 02:03 PM
CobraEatr
Jul 29, 2002 11:46 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
