Grrrr....why won't my mac y-pipe line up with the collectors???
Old Jul 4, 2004 | 10:00 PM
96redformula7's Avatar
I don't know why the mac y-pipe is not lining up to the collectors. Do you all have any idea's why??? I put the headers on bolted them down.The y-pipe is short about and inch or two!
Old Jul 4, 2004 | 10:15 PM
YYLT1Z28's Avatar
This is a common problem with Macs, the same thing happened to mine. I just took it to a muffler shop and they cut the y-pipe in half and re-welded it so it fits perfectly with no leaks.
Old Jul 4, 2004 | 10:55 PM
Shall I just drive it to an exhaust shop and let them fix it??
Old Jul 4, 2004 | 11:41 PM
CobraEatr's Avatar
That's what I would do.
Old Jul 4, 2004 | 11:54 PM
Kataklysm's Avatar
The exhaust shop that put my y pipe up said it fit awesome and usually they have problems with y pipes but mine was a perfect fit.
Old Jul 5, 2004 | 12:02 AM
disco192's Avatar
Try putting the drivers side in 1st and dont tighten the bolts much. Then try and get the passenger side to bolt in. Dont connect the cat (or off-road pipe) until after you already have the other 2 pieces bolted (not necessarily tight) down.
Hope that helps. I know they can be bitches sometimes.
Old Jul 5, 2004 | 12:32 AM
woundn't the safer thing be to just have the exhaust hop extend the pipe by an inch so that I don't put any stress on the headers bolts in the ALUMINUM heads. I am thinking might as well take it, have them extend the y-pipe connect the s-pipe and weld me a straight pipe in their to finish off my exhaust.
Old Jul 5, 2004 | 12:33 AM
OH yeah, any idea's as to how much they will charge me to do the listed above. around $1more or less??
Old Jul 5, 2004 | 10:43 AM
Bud M's Avatar
My Hooker shorty y pipe didn't fit right either. The instructions said to put the headers and y pipe together loosely then start tightening everything a bit at a time. I cut the y pipe instead and had them splice it back together at the muffler shop. Otherwise I was afraid I would constantly fighting leaks and broken fasteners/stripped bolt holes.
They can fix it fairly easily and it won't cost you a lot, probably $25.
Old Jul 5, 2004 | 11:21 AM
12SCNDZ's Avatar
I didn't have any fit problems whatsoever with my MAC Y-Pipe.
Frank
Old Jul 5, 2004 | 11:51 AM
RamAir95TA's Avatar
Mine fit just fine. No problems.
Midnight_Z
Feb 16, 2016 09:36 PM
TitoPR221
May 26, 2015 12:20 AM
Collector Car
Jan 5, 2015 10:58 AM
