Guys with Joe O cams/valve lash question
Old Jul 5, 2004 | 10:45 AM
Fastbird93's Avatar
How did you guys adjust your lash??? Static or dynamic???
Old Jul 5, 2004 | 11:11 AM
bunker's Avatar
dynamic while engine is running.
Old Jul 5, 2004 | 11:24 AM
Fastbird93's Avatar
Cool. How much lash did you throw at it??
I'm going to have to go a static first, just because I've either got some valves too tight that's bleeding off cylinder pressure causing my backfire through the intake, or my opti is shot.
Old Jul 5, 2004 | 11:52 AM
disco192's Avatar
Valve lash isnt dependant on the cam, it varies with different lifters. Stock lifters require 1/4 turn past zero lash to as high as 3/4 past. Comp-R lifters usually run best at zero lash or 1/8 turn past.
Stock lifters are better to adjust while running, but the comp-r lifters make a little more noise and the "tighten until the noise goes away" method doesnt always work. I would go with comp specs and tighten them until straight up zero lash when the engine is cold and see how that works for you.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Joes96z
Dec 14, 2014 04:03 PM
Joes96z
Dec 13, 2014 07:48 PM
Red97LT1
Aug 7, 2002 05:45 PM
Brent94Z
Mar 21, 2002 04:44 PM
