Grounding Kits for LT1?
Originally posted by got_hp?
if there wasnt a significant bottleneck (resistance) to begin with, then you wont see any change.
Waswa
Originally posted by Grease
That was my point. A grounding kit is like replacing worn out sparkplugs. Only install when needed, or simply clean you grounds. But thats just my opinion.
Waswa
Waswa
Waswa
Waswa
You guys don't even have to go through all that crap... just go to auto zone they can check out all that stuff for you for free if you don't have the tools.
If it aint broke don't fix it.
I could see where there might be a noticable difference if you have cartain items wired into the harness... but you should always run things that need a straight voltage right to the battery. did it with the pump, the ign box... and every body is happy... Voltage is where it should be. Things are allot easier to keep an eye on too.
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
CARiD
Dec 26, 2014 04:20 AM
