griffin 25241
Old Jan 21, 2010 | 08:46 PM
chevyrules85's Avatar
griffin 25241
i just got the new griffin rad, and im getting ready to put it in, and just wnated to hear from people that have the same rad, just wondering what you used for hoses and fans. the thermostat hose runs down to the lower passenger side part of the rad right? i noticed they are very different sizes... just wondering what to do for hoses and fans at this point, thanks guys!
Old Jan 22, 2010 | 03:17 PM
94SLUG's Avatar
I used all stock hoses, for fans I had real problem, I had the oil cooler put on for some reason... I used Summit dual 11s puller fans work to perfection... Singke would not cool the car in 90+ heat....
Last is old setup
Old Jan 25, 2010 | 04:24 PM
anyone else?
Old Jan 30, 2010 | 03:07 PM
has anyone used one of flexalites dual fan set ups on this rad? wondering which one to go with
Old Jan 30, 2010 | 04:25 PM
94SLUG's Avatar
It all depends, the flex 220 dual pullers would not fit, the trans cooler, oil cooler, steam vent, and both rad hoses would not allow for a snug tight fit, I did'nt opt to cut 4 holes in a set of 250 dollar fans........ Pusher option would not keep the car cool in 90+ temps outside (same fans)... Single mono flex puller also would not keep it cool.... If you have a man trans the flex 220 should work, but still requires modifications!!!!!!!!!!!!!!!
Old Jan 30, 2010 | 04:27 PM
94SLUG's Avatar
Off the top of my head the space you have to work with is 16.5 by 10 inches, the fin area... I wouls suggest you buy the fans at NAPA so you can return easy, and they do sell flex products.
This guy did it with flex 220, but as you can see it does not fit correct, and that will result in a huge loss in cooling.. The turbo setup looks perfect though...
https://www.camaroz28.com/forums/sho...d.php?t=669343
Old Jan 30, 2010 | 05:18 PM
well your a little off, i have about 15 in height to work with, and 22 width, for the finned area. theres no way the summin dual 11 fan set up would work, its 18 high. must be a different rad? i have the griffin 25241
Old Jan 30, 2010 | 05:38 PM
what if i used 2 of these?
http://www.summitracing.com/parts/PRM-19120/
the cfm says 2350, for one.... seems a little high to me? if thats right, 2 would be plenty right? i know theres no shroud, but all the dual fan set ups seem to be to wide to work with my 22 inchs of width...
Old Jan 30, 2010 | 08:21 PM
94SLUG's Avatar
Same rad, and I was off on the sizes, but its the same radiator... I did a lot of post on this issue...
These workhttp://www.summitracing.com/parts/SUM-G4852/
Those 10s would not do the job IMO..
Old Jan 30, 2010 | 11:41 PM
Height (in) 18.437 in.
do you have any pics of how you made this work out? or is the summit measurement wrong? it doesnt look like 18 and a half in the pics since its only an 11 inch fan...
but my total heigh is 15.5, and the fin area height is 14 total. thanks!
Old Feb 1, 2010 | 04:08 PM
94SLUG's Avatar
MY BAD These fans http://www.summitracing.com/parts/SUM-G4850/... It was a long time ago, and the car is not here (storage)
12.000 in.
Height (in) 15.000 in.
Width (in) 26.000 in.
Thickness (in) 3.240 in.
Number of Blades 10 blades
I had to do some very minor mods to fit!
Old Feb 1, 2010 | 05:59 PM
hmmm i see. looks likess those are about 4" wider than the finned area i have to work with. how did you make that work? thanks!
Old Feb 3, 2010 | 01:14 PM
94SLUG's Avatar
Top pic, it fits the tank welds to perfection
Old Feb 3, 2010 | 03:40 PM
hmmm, so SUM-G4850 is the fan in the pictures? maybe i measured wrong, those are dual 12s too? just making sure i got the right number before i order them so i dont have to send them back, thanks alot man!
jer4251
All Non-Automotive
Dec 23, 2006 04:29 AM
CMSDave
10
Oct 27, 2004 04:19 PM
Pro Stock John
Jan 16, 2004 09:25 PM
