fan question
Old Feb 3, 2010 | 05:39 PM
bslaughterback's Avatar
fan question
I have a 1996 Z28. And I want to use this set up to activate the fans at a cooler temp. www.summitracing.com/parts/jet-60602/. jet gm fan switches. The application shows only for 1993 through 1995 Lt1s. Has anyone used this on a 1996. Or is there another product that will work the same way.
Old Feb 3, 2010 | 06:20 PM
19z28camaro02's Avatar
Short of sending the PCM out to be retuned.......hypertech power programmer if you're using a mild bolt-on setup
Old Feb 3, 2010 | 08:02 PM
I suspect the year limitation might be because it may cause a check engine light for the fan relay circuits (because of OBD-II).
You could go the reprogramming route or make a fan switch for a few bucks in parts.
Magenta_Hearts
Mar 29, 2017 08:54 PM
linz
3rd Gen / L98 Engine Tech
Apr 7, 2015 11:49 AM
ChrisFrez
Mar 1, 2015 01:33 PM
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
