got compression!!
Old Apr 27, 2010 | 10:54 PM
StangCrusher350's Avatar
got compression!!
got the car fully together today. i tried turning it with a near dead battery...it turned a bit, thats all. let the battery charge a bit and turned it again...turned much faster but not all the way there. there is lots of compression, but it sounds like it is taking a lot for the engine to make the compression if that makes sence. kind of like the roller rockers are waayyy too tight. would that cause this car from turning over??
Old Apr 27, 2010 | 11:07 PM
RamAir95TA's Avatar
Did it start?
Old Apr 27, 2010 | 11:25 PM
no buddy. just turned. i dont have the radiator itself hooked up so i dont wanna start it too long if it did. its so close. if i let it turn for about 2 1/2 to 3 sec ill start hearing that turn from start to run but then it stops and the engine just keeps cranking over
Old Apr 27, 2010 | 11:56 PM
Old Apr 28, 2010 | 05:20 AM
Guest47904's Avatar
Guest
Wouldn't that be the opposite of your problem? If the rockers were too tight, the valve(s) would stay open longer and relieve the compression to turn over easier.
Have you spun it over with the plugs out?
Old Apr 28, 2010 | 06:47 AM
these plugs were the biggest pain to get in with these headers. i have no want to take these out again lol. but if i have to i guess i will.
Old Apr 28, 2010 | 06:41 PM
hsyr's Avatar
Could be time for a new starter and battery
Old Apr 28, 2010 | 09:32 PM
When you were finished installing the rotating assembly, did you measure the torque required to rotate the assembly?
Old Apr 29, 2010 | 12:23 PM
found the problem. my dad did the rockers and well i knew this but didnt bother to tell him. after tightened, they loosen back up again after settling. he did not know this and he re tightened all of them once over. so the rockers were not NEAR proper spec. i re adjusted myself yesterday, car started right up a little bit of smoke came from the secondary exhaust holes, but other than that, the car seemed fine. but it was the first start in over 11 months of winter so i was prepared for a little smoke
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
