Is this a good rotating assembly?
Old Apr 20, 2005 | 12:18 PM
jchevy's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
I want to slowly start putting a bottom end together for my car. With 100,000 miles on my stocker i know i am living on borowed time. Is the kit above a decent kit? I really dont know much at all about rotating assemblies, I plan in having a machine shop assemble it for me.
Goal for the car is to stick with my current heads and cam and rev to about 6500 rpm.
Old Apr 20, 2005 | 12:24 PM
DavesLT1's Avatar
Re: Is this a good rotating assembly?
not a bad price, but note that it is a cast assembly and not forged. it won't handle the HP of a forged, so you might want to spend the extra $500 in case the mod bug gets you and you want power adders like big N2O shots.
Old Apr 20, 2005 | 12:31 PM
jchevy's Avatar
If I ever do anything more to a car it will just be a bigger cam, never plan on going the power adder route.
Is there any problems with using a cast assembly but forged pistons? Like this auction?
If I never go with a radical cam is a 383 even worth it? Chances are I will stick with the top end that I have and not change cams, the car isnt an everyday driver, but it does see a lot of street time.
One suggestion made to me was to use a stock crank and rods, but get some good forged pistons? Would that work for what I want to use the car for? Want to be able to safely and reliably see 6500 rpm and stay on 91 pump gas.
Old Apr 20, 2005 | 12:55 PM
1-bad-z28's Avatar
stick with stock crank and get h-beam rods and forged pistons. Obviously this is not for a stroker. Get some 30 over pistons and make it a 355
DirtyDaveW
Mar 15, 2015 07:01 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
thenewkid
Nov 27, 2014 09:41 AM
1LEThumper
Jul 14, 2003 12:45 PM
