Good cam for 383 LT1?
Old Apr 17, 2009 | 04:44 AM
  #16
bombebomb's Avatar
Originally Posted by reamo04
bombebomb, maybe you should chime in since you have a 383 with a cam and stock heads
what cam do you have? how do you like it
Well,
Using a lunati 60122 231/239 535/550 seems to do fine for me does not seem like it lacks any power at all. I could drive it everyday with the mail order tune that is in it now personally. Not sure what others would think because performance overrides comfort for me.
Overall I like it but like I said I am quite tolerate of how a car drives, so someone else may or may not like it. Plus I am on a mail order tune AND a stock stall which if it does have any surge in it I will feel it. The cam obviously would benefit from ported heads as with any cam, but for stock heads it runs pretty good IMO.
Keep in mind mine is not dyno tuned which can really help get that "surging" out people experience.
Old Apr 17, 2009 | 12:17 PM
  #17
97 6SPEED Z's Avatar
Post
Originally Posted by MikeGyver
Also, is it really necessary to use new roller lifters with a new cam? How about new pushrods or springs?
He's on a tight budget and can do $300 for a cam but probably not $600 for everything.
No, the roller lifters and pushrods do not need to be replaced with just a cam swap ....... provided they were appropriate for the original valve train set up. That is, for example, hardened pushrods with guide plates on a non self aligning rocker arm set up. Valve springs are a different matter however .... they must be capable of supporting any higher valve lift numbers due to the cam swap.
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
thenewkid
Nov 27, 2014 09:41 AM
cristian1311
Nov 23, 2014 02:22 PM
Queens94z28
Nov 20, 2014 06:03 PM
