Opti on top: working great :)
Old Dec 15, 2008 | 08:36 PM
kazdevil's Avatar
http://farm4.static.flickr.com/3249/...a686fda5_b.jpg
http://farm4.static.flickr.com/3097/...38b7c088_b.jpg
http://farm4.static.flickr.com/3076/...fc823987_b.jpg
http://farm4.static.flickr.com/3261/...e195942d_b.jpg
http://farm4.static.flickr.com/3173/...29841f70_b.jpg
Old Dec 15, 2008 | 08:43 PM
mdacton's Avatar
Old Dec 16, 2008 | 11:48 AM
marshall93z's Avatar
Wtf?!
Old Dec 16, 2008 | 12:39 PM
camarobird92's Avatar
WTF??? X2!!!! Why would you go to all the trouble of building that when a standard SBC distributor would work?
Old Dec 16, 2008 | 12:45 PM
mdacton's Avatar
b/c he needs it to operate the pcm for fuel.....
I have seen this done before, but they used a distributor cap and regular wires...not the single coil deal.
Old Dec 16, 2008 | 12:53 PM
Sick97SS's Avatar
damnnn, if it runs, more power to ya man.
i wish my car was that easy to work on, thats the biggest engine bay i've seen other than my brothers 89 lincoln town car.
Old Dec 16, 2008 | 01:38 PM
ToocoolZ28's Avatar
Nice, what is that, a 79-80 Cutlass?
Old Dec 16, 2008 | 01:40 PM
wrd1972's Avatar
Now there is something you dont see everyday.
Why will the standard opti location not work here.
Old Dec 16, 2008 | 02:57 PM
kazdevil's Avatar
This is a 1984 buick regal. The owner has always been a carburetor guy. I convinced him that he will make more power with fuel injection.So I did the harness and tuning for him. The reason I made the opti on top is that this engine is a 383ci old block- not a LT1- so we cant fit the LT1 opti in its original place.The owner didn't want to spend money on the conversion and change the front end. So I thought this might work. and It did. The owner is happy about the conversion and said that he is not going back to carburetor again.
Old Dec 16, 2008 | 03:16 PM
sbs's Avatar
sbs
Isn't that an LT1 WP in the picture?
Cheaper to do all this custom work than to use an LT1 block?
Old Dec 16, 2008 | 03:52 PM
WS6T3RROR's Avatar
Question of the day is how did you index it with the engine though?
I have seen this done before but with a modded lt1 timing cover and just the optical section of the opti and using a crab cap dist to fire the plugs with power from a stock coil and icm, but that gets set up the same as a stock lt1 opti when bolted in place.
I have seen like what you have done before, but nobody has ever been able to tell me how you line the thing up so everything is accurate like a stock opti install.
Old Dec 16, 2008 | 04:28 PM
Stl94LT1's Avatar
Good observation. If it is not an LTx block, what is driving the water pump?
Old Dec 16, 2008 | 04:38 PM
83tpi_3rd-gen(sri)'s Avatar
what heads is he running if its not an LTx block?
Old Dec 16, 2008 | 05:39 PM
kazdevil's Avatar
well, its a LT1 block, but the rotating assy is not. The crank pully is too close to the timing cover.
Heads are GM LT4, LT4 intake and 306 compcam.
To line the thing up, what I did is basicly installed the dist-opti whit piston 1 on tdc- rotor to #1 and turn it left and right till the engine started, hold it there, checkd the timing on the scan tool, compared it with whats in the timing tables and used a timing light to make sure that evrything matched. when it did, I made a bracket attached to the base of the dist-opti ond bolted to one of the holes in the intake - where the egr used to be. I will take more pics of that soon.
Old Dec 16, 2008 | 07:15 PM
wrd1972's Avatar
I applaud the effort here, but it sure seems like an painfully aggravating way of making things work.
I still dont undestand why the opti would not bolt on the front.
