Gauging Interest in "BIG" CID LT1 Block
Old Apr 18, 2009 | 02:35 AM
  #31
Rob94hawk's Avatar
Originally Posted by TUNDRKYS
Anyone mind me asking what's the point?
For those interested, is that only if it's less expensive than building an LS1?
Why not build a big CID Gen I?
I could still use the pcm and harness without spending thousands for a different engine.
Old Apr 18, 2009 | 11:49 AM
  #32
kgkern01's Avatar
SHP blocks are around the $1500-1800 range typically. Considering that machine work on the weaker stock block to make a 4-bolt splayed 383/396 is not too much less than that, then of course it will be MUCH cheaper. You can keep ALL of your current accessories, wiring, PCM, fueling, transmission, etc without changing anything whatsoever, just as if doing a regular rebuild...except that you end up with MANY more cubes.
Old Apr 18, 2009 | 12:45 PM
  #33
caldercay's Avatar
Originally Posted by Rob94hawk
For whatever reason it's not letting me register.
Yep - there is no captcha image displayed. Sheesh. Anyway, I'd be
interested - actually, I'd be interested in two blocks.
Old May 7, 2009 | 09:54 AM
  #34
Rob94hawk's Avatar
Well, is this project hype or what?
Old May 7, 2009 | 11:14 AM
  #35
camaro1fastz28's Avatar
i am in
Old May 7, 2009 | 01:23 PM
  #36
bombebomb's Avatar
It took them days to send me my activation email.
Old May 7, 2009 | 09:24 PM
  #37
Mike94ZLT1's Avatar
Originally Posted by <Puck>
A stroked LSX makes 10 more horsepower every time you wink and smile at it.
Old May 8, 2009 | 01:32 AM
  #38
Wild1's Avatar
I am interested since I'm prepping for a project build now. My purpose is the silver state classic. What is the timeline.
I'm gearing up for a 396 but can wait a few months.
I live in cali if you need to pilot and test.
Old May 8, 2009 | 07:19 AM
  #39
hghpwr's Avatar
Iam all for a big inch lt1 and Ill worry about the head flow later,there are a lot of big blocks that the heads don't have big flow numbers and produce very good power.
Old May 8, 2009 | 10:34 AM
  #40
95firehawk's Avatar
Build a good foundation and the heads will follow.
Old May 8, 2009 | 11:01 AM
  #41
blue 79 Z/28's Avatar
AFR 227cc eliminators are the same potential as the gen 1's also AFR is coming out with a 235cc version really soon also, hopefully they make an LT1 version of the head also. both those heads will be capable of 700hp n/a in a proper buildup.
Old May 8, 2009 | 06:21 PM
  #42
mdacton's Avatar
Dart says they can't even move the cyl. heads for LT1's...and the dude laughed when I mentioned this
Old May 8, 2009 | 08:51 PM
  #43
Rob94hawk's Avatar
So is Dart going to **** or get of the pot already?
Old Jul 4, 2009 | 01:27 PM
  #44
camaroe3's Avatar
Originally Posted by AdioSS
There is an Impala guy who will convert Donovan aluminum blocks to use the LT1 parts. They are expensive, but you can get 500" out of them. The one in his car now is holding well over 1000hp.
The SHP blocks run around $1500 and are good for 600hp. A Little M is about $1000 more and good for a lot more power.
Well I would be will to put money down and get on a waiting list for a block. I think If the block is only good for 600 hp then they might not want to even produce it.
I would be happy with a lt1 block , 4inch stroke and 4.0-4.155 bore . If it is weaker then a stock block why even build it?
also I would like to keep my 1 pc rear main seal on less they make a kit to keep the 1pc rmc crank
Old Jul 4, 2009 | 06:44 PM
  #45
Steve in Seattle's Avatar
I'm still waiting to see even ONE example of a 750hp LT1 without power adders. 500? sure... a good 396 can get there. 550? ok, I'll give ya that... but 750?! LMAO.
Seriously, no 23* LT1 heads can really get past ~310cfm (and I'm being generous here)... asking for even 620 is pushing the bounds of reason. Custom, raised runners, sheet-metal intake, aftermarket PCM, say a 8500 redline on a solid roller and sure, you can get close to 600 if a miracle happened ... but 750? I must be missing something here.
Did the Dominion heads ever get ironed out? Did someone launch an 11* LTx head?
The truth is that finding even a Gen I SBC head/cam that can make 750 at the crank with a 7000 redline is rare... casting a custom 427 LTx block to try it seems like a fun project to burn tons of cash.
There's already been an aluminum 427 LTx block and the owner never set any records with it other than displacement.
WAY more market would exist for an aluminum LTx block instead. 100pounds off the front would be worth more than the price IMO.
