Gauging Interest in "BIG" CID LT1 Block
Old Jul 15, 2009 | 10:46 PM
  #61
Rob94hawk's Avatar
Originally Posted by kgkern01
As far as this block goes, I hope that Dart can make it a 1-piece main block, as a 2-piece block would require a different oil pan and flywheel assembly, and at that point the options available for say T56 cars with the stock k-member goes down as far as flywheels and oil pans are concerned. I think the ability to still use an (aftermarket of course) F-body LT1 oil pan should be retained as well as LT1 flywheel. JMO
IMO I think it's a must to swap out the K frame for an aftermarket one regardless if you are using the stock pan or not. Anything to decrease front end weight. But this is just me.
Old Jul 16, 2009 | 12:15 AM
  #62
kgkern01's Avatar
Unless you do ANY autox or RR, the stock k-member is the only one strong enough to handle the side loads that kind of racing puts on them...
Old Jul 16, 2009 | 11:42 PM
  #63
Rob94hawk's Avatar
That would make sense.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Collector Car
Jan 5, 2015 10:58 AM
