Gauges???? What should i order?
Old Nov 2, 2003 | 03:41 PM
87transam383tpi's Avatar
I am ordering some gauges (2 2 1/16") to put in my A-pillar gauge pods. I was thinking a transmision temp one and something else. What is everybodys opinion? Thanks
Josh
Old Nov 2, 2003 | 03:55 PM
ishz28's Avatar
I like the Phantom gauges. I use tranny temp and oil temp. in mine.
Old Nov 3, 2003 | 09:57 AM
Ditto..... oil temp and trans temp in the A-pillar. Fuel pressure, nitrous pressure and oil pressure in the center A/C vents. Click on "Step into my office...." below for a pic.
Old Nov 3, 2003 | 09:59 AM
S.J.S.'s Avatar
I guess its a clean sweep....just installed mine. Same here cept I went with the ultra-lites.
Old Nov 3, 2003 | 10:01 AM
"White Knight"'s Avatar
Tranny temp??? Who cares about tranny temp.
I would get Air/Fuel raito.......what can you do about your tranny temp anyway......all you can do is ease it up and everyone knows how hard there driving it----you can guess how hot it is how hard you run it
Old Nov 3, 2003 | 10:30 AM
S.J.S.'s Avatar
UH NOO. Maybe you can run a trans cooler.....I know guys that put in 2. Trans temp is what kills tranny's especially those with high stalls. At least you'll be able to know when to ease off on it. How can you know without a gauge.
Old Nov 3, 2003 | 10:38 AM
Tranny temp??? Who cares about tranny temp......... what can you do about your tranny temp anyway......all you can do is ease it up and everyone knows how hard there driving it----you can guess how hot it is how hard you run it
Hmmmm.... lets see.... 800 ft-lb through a non-locking 5,000rpm flash stall TH400, with an external, manually switched, fan-assisted cooler. What's so stupid about monitoring the fluid temp?
Apparently you like psychedelic light shows, and the limited accuracy of the info you get from the stock, narrow-band O2 sensors.
Old Nov 3, 2003 | 10:40 AM
S.J.S.'s Avatar
Ya killin me Fred. I knew you would come back and for once I beat you to the punch. But as usual.....ya top me. Thats okay..at least were on the same page...well I am anyway you always are.
DirtyDaveW
Dec 1, 2016 05:37 PM
Biggiebound
Apr 21, 2015 11:28 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
97z28k&N
Jan 9, 2015 04:58 AM
Rich_z28
Aug 29, 2002 10:44 PM
