fule pump went out...?
Old Apr 30, 2009 | 09:57 PM
Nick-camaroSS's Avatar
1996 camaro Z28 SS
so today i was heading home. as i was down the block the car started to bog and sputter real bad ( out of gas ) so i berly get it home. i get some gas put it in it and it wont start. put about 4gallons in it. i thought it was possibly the fule filter so i threw a new one on... still nothing. i then took some starter fluid and sprayed it in my carb. and it only runs for a second. ( only when fluid is sprayed in carb )
Im guessing its the fule PUMP. if your thinking the same thing... witch is the best way to replace it? by dropping the gas tank or what...?
Old Apr 30, 2009 | 10:04 PM
Why not put a pressure guage on it and see if the pump is working? Always better to do a bit of diagnostic work before randomly buying parts and hoping it will fix it.
Old May 1, 2009 | 02:26 AM
henryz28's Avatar
Search access door mod.
HectorM52
Jul 30, 2017 11:46 AM
Apr 24, 2015 01:03 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
ANDYZ28
Dec 29, 2014 09:13 PM
