fuel shutoff
Old Aug 18, 2004 | 10:51 PM
acslinger2525's Avatar
fuel shutoff
I was out joy riding in the Z today, and it has the walboro 255 fuel pump just recently installed. I wound up first gear and when it went to second i lost all fuel, the rpms went from 5000 to 1000 and when i pressed the pedel it felt like it the throttle cable had broke. I checked the throttle body and the butterfly still opens. My question is do i have a fuel reset or maybe a fuel relay that may have went out? thanks
sc smith
Old Aug 19, 2004 | 11:22 AM
Re: fuel shutoff
nevermind, its my Opti
Old Aug 19, 2004 | 11:50 AM
Gos2Slo's Avatar
Re: fuel shutoff
Bummer man, Autozone has a lifetime warranty Opti for like $30 plus the core. Check/change your plugs and wires while you're in there.
Old Aug 19, 2004 | 12:15 PM
Re: fuel shutoff
i just had the plugs, wires, fuel pump, injectors, cam, headers, heads, all new ignition parts, fuel regulator and all the other bolt ons put on. It runs so good, but i guess it puked. I am just going to look at getting rid of this opti. Its only got 15 miles on this one. GM one at that.
Old Aug 19, 2004 | 12:35 PM
Gos2Slo's Avatar
Re: fuel shutoff
Should be under GM warranty then , no question. Give em hell!
Might just be a loose wiring harness though, check it over just to be sure.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
taner
Aug 23, 2002 05:25 PM
tbyrne
Jul 2, 2002 05:37 PM
