which fuel pump should i get?
Old Oct 13, 2005 | 08:54 PM
red96z's Avatar
when i do heads i will add 30lbs injectors and i will need a pump which should i get??
Old Oct 14, 2005 | 02:49 AM
FuryZ28's Avatar
Re: which fuel pump should i get?
Racetronix PnP 255lph pump. Simple installation, minor modifications, very easy to work with. If you're looking for "hassle-free" I wouldn't look any further than the Racetronix fuel pump. Most retailers also sell it with a voltage booster kit, which runs a wire from your alternator to your fuel pump to boost voltage to the pump, and ultimately increase the output of the pump.
Old Oct 14, 2005 | 03:14 AM
2000GTP's Avatar
Great pump, also a great kit.
Old Oct 14, 2005 | 04:54 AM
Dansean1's Avatar
If you have a hard top, cut out the metal above the fuel tank, its not hard, their are websites to assist; I've done it myself.
I would recommend the Walbro 255 pump. I believe they are used in all newer Ford's.
Racetronix is also good. Its a matter of preference. The walbro is cheaper and I think universal. Please verify this.
Old Oct 14, 2005 | 12:15 PM
cas0484's Avatar
Another vote for the Racetronix 255lph Pump. Great product, easy installation, great results
Old Oct 14, 2005 | 12:37 PM
jerrysta's Avatar
I thought the Racetronix pump was made by Walbro?
Old Oct 14, 2005 | 02:33 PM
cas0484's Avatar
It is a Walbro pump, sorry for the confusion.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
