Exhaust leak? help.
Old Oct 13, 2005 | 11:11 PM
Dansean1's Avatar
Exhaust leak? help.
For the past two months now, Ive had an exhaust leak from the driverside manifold, 99% its coming from there.
My friend said he could he the gasket blown out; I couldnt see it but the ticking noise goes away more after the metal has heated up.
Is Ebay a good place to buy some replacement copper gaskets?
Ive heard copper is a good material to use and in some cases can be reusable, for future header upgrades.
The exhaust leak now is annoying and some of the exhaust may not be allowing the 02 to snif everything.
Old Oct 13, 2005 | 11:12 PM
69gto96z's Avatar
Re: Exhaust leak? help.
As far as I know, you must have the thin metal gaskets for stock manifolds, but I could be wrong. Also, I have never bought gaskets off of ebay, so I couldn't help you out on that one.
Old Oct 13, 2005 | 11:33 PM
FastZinTennessee's Avatar
Fel pro + a little orange RTV around the ports = win.
Old Oct 14, 2005 | 03:17 AM
2000GTP's Avatar
Exactly what I did with my header gaskets and haven't had any leaks since.
Old Oct 14, 2005 | 02:57 PM
F Carline 94's Avatar
It is probably leaking because a bolt is broken. You'll be lucky to get away with a gasket only problem. If I was keeping the stock manifolds, I would get GM OEM gaskets.
Good Luck
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
FredM
Mar 6, 2015 03:04 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
