Fuel pump problem?? Help the Newb!!
Old Jul 18, 2008 | 04:45 AM
garrettwichert's Avatar
I started my car today, ran fine. Shut her down went into a store for 5 minutes came back out and she wouldn't start. Tried again and she had to crank for 5-8 secs before it fired. When it did fire she ran good, with good oil pressure and idles fine with no misses and no loss of ponies that I noticed. Temp outside was about 95 with a heat index in the triples digits. Don't think the coil was hot......I think I might be losing the fuel pump. Any suggestions. I feel scared and alone, someone help me!! Please!
Old Jul 18, 2008 | 05:21 AM
Easiest way to diagnose the fuel pump is to check the pressure at the Schrader valve on the hardline behind the intake manifold. At idle, look for 41-47psi with the vacuum line off the fuel pressure regulator, and a 6-8psi drop when you put the vacuum line back on. At WOT/max engine load the pressure should stay above 40psi. When you shut the engine off, fuel pressure should not drop rapidly.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
