which fuel pump to get??
Old Mar 28, 2004 | 12:37 AM
slashz28's Avatar
hi guys i need recommendations on which fuel pump to get please. its for the car in the sig: c306 cam, 30# injectors, etc. the stocker is dead. get a stock replacement pump? or go walbro or something? i see lots of people using walbro 255 pumps etc. on here. is walbro cheaper? are they durable? i dont own the car anymore, im posting for the new owner. thanks
Old Mar 28, 2004 | 12:45 AM
97Camaro007's Avatar
Get the Walbro 255...it's a cheap replacement for $100....thats what i did....no problems yet
Old Mar 28, 2004 | 01:42 AM
jcolez28's Avatar
There are two Walbros for the car. One is the regular and one is high performance one. The regular is on ebay for 99 but you can get the hp for about 110.
Old Mar 28, 2004 | 04:12 AM
ishz28's Avatar
I believe the High Pro is used for higher than normal fuel Psi's. The regular one for stock Psi's
Old Mar 28, 2004 | 04:29 AM
MentalCaseOne's Avatar
How about installation for the HP WB? any diff than the stocker WB??
If I am gunna do the job may aswell upgrade at the same time
Marvin
Old Mar 28, 2004 | 11:26 AM
Red96Lt1's Avatar
Get the racetronix kit from thunder racing. They use the 255 pump that is good for 800 HP. And it's pretty much plug and play. It doesn't come with instructions, but if you email them, they will more than likely email you back within like 10 min with some instructions.
Old Mar 28, 2004 | 12:40 PM
Dave88LX's Avatar
More Performance has the RaceTronix for a little bit cheaper IIRC.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
