Fuel pump dieing or opti?
Old Jul 27, 2004 | 09:15 PM
1 Nasty Bird's Avatar
My 95 T/A has a high RPM stumble sometimes. It seems pretty much random. Basically when i go WOT sometimes around 4500 or so itll fall on its face and stop accelerating and youll here a loud POP POP POP sounds lie its in the exaust, i have stock manifolds cat and just a flowmaster muffler not the whole catback.
Now this seems like when my old t-bird had a dieing fuel pump. But with all this funy optispark buisness i dont want to waste $ on a pump if i dont need one now?? I dont have a fuel press gauge i can use right now, any other way to check or symptoms to be looking for? I also have a problem that has only occured 3 times in the last 3-4 months i owned the car where if im at a stand still in gear and hit the throttle hard itll just make a "pop" and not accelerate just like the high RPM miss. Its very rare that that happens, but if that happened at the wrong time it could get me in an accident so i need to fix this. Any and all suggestions appreciated.
Old Jul 27, 2004 | 10:15 PM
Mtdewandal's Avatar
Re: Fuel pump dieing or opti?
Sounds similar to the problem i've been having, mine backfire like that through the exhaust. I just changed the plug wires on mine but haven't tried it out to see if that fixed it or not, and I know it's not my fuel pump because I hear it when I switch on the ignition. How old are your plug wires, maybe you should check those as well.
Old Jul 27, 2004 | 10:29 PM
944v8inDFW's Avatar
Sounds like you are going lean. Maybe think about the fuel filter if has been awhile and check the fuel pressure.
Old Jul 27, 2004 | 11:13 PM
ya ive had a fuel filter in the backseat for 2-3 weeks havnt had a chance to throw it in yet, i was gonna do it when i bought it cause i was doing rear brakes. Damn autozone mispackaged it, the package was the right part # but it had the push on fitting on both sides. It was my first time doing an F body so i dindt notice till iw as under the car. damn deutsch or dousche or however you spell it
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
