2 big stud connectiosn on starter. Which does + connect to
Old Jul 27, 2004 | 04:51 PM
ZDriver96's Avatar
ok i basically done putting my LT1 motor into the car... well i am except for y pipe and clutch fork.. and im starting to doubt myself... So Just for my comfort, when you are underneath the car and looking directly up at your starter there are 2 fat studs, both are the same size. 1 is on the bottom part of the starter, the other is on the top part of the starter.. Which does the + battery cable connect to on the starter. The lower stud or the upper stud..
Thanks.
Old Jul 27, 2004 | 07:19 PM
30696bird's Avatar
Re: 2 big stud connectiosn on starter. Which does + connect to
I hope this helps you out. http://shbox.com/1/starter.jpg , Shoebox has ALL the anwsers. If you have anymore doubts go to his website and you can't go wrong........unless you're a moron . His site really does make things easier.
Old Jul 27, 2004 | 09:11 PM
RE AND CHERYL's Avatar
Upper stud. I beleive you will find the lower stud already has a braided wire connected to it and running into the starter.
Old Jul 27, 2004 | 09:14 PM
CamaroBoy96Z28's Avatar
There is only one way to connect the wires. Each of the two studs is a different size. As previously mentioned, the third wire is built into the starter and isnt of concern.
Old Jul 27, 2004 | 11:28 PM
ZDriver96's Avatar
Wait clearly in that picture its the lower stud.. Cuz u can see the oil pan bolts.. then look over at the starter and the + cable is plugged into the bottom one..
Those 2 studs looked the same size to me.. but i didnt try hooking it in..
MadMav
Jun 15, 2015 09:51 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
KamikaZ28
May 28, 2015 12:45 AM
gomaro
Events and Cruise Spots
May 6, 2015 09:02 AM
