fuel pump
fuel pump
Need a little help.car has set for a few days,get in to start,stumbles,wont start.After that it just turns over and over,wont start.Fuel pump clicks but I cant hear it prime.Car ran fine before.Any help is appreciated.
Check it out.....
https://www.camaroz28.com/forums/sho...mp+replacement
This seems like the way to go.
Good luck,
Ivan
Good luck,
Ivan
Check the fuel pressure.
If the pump is not starting for at least two seconds when you turn the key to "on", use a 12V source to connect to the fuel pump prime connector, and see if the pump runs. That takes the relay and the various "permits" (e.g. PCM) out of the circuit, and allows you to trace down the source of the problem.
http://shbox.com/1/fuel_pump_prime.jpg
10-31-2016 11:09 AM
