Fuel pump
Old Nov 30, 2004 | 03:41 AM
Got-LT1's Avatar
Fuel pump
how hard is it to change a fuel pump? I'm going to replace it and the injectors in a month or so. Also where can I get new fuel rails?
Old Nov 30, 2004 | 05:00 AM
DarkKnightZ28's Avatar
Re: Fuel pump
The fuel injectors are easy, I just read the removal process in a Hayne's Manual and then had no problems. I've done them now a few times so I've gotten the time down now to about 20 mins. to remove and replace them.
Old Nov 30, 2004 | 02:48 PM
Got-LT1's Avatar
Re: Fuel pump
Yeah, injectors are easy, had to do one on my brother's car, but how hard is the fuel pump? I understand it is in the gas tank and just wanted to know ow hard it is to get out of there.
Old Nov 30, 2004 | 02:59 PM
Red96Lt1's Avatar
Re: Fuel pump
Do a search, this has been discussed alot lately. Cut a hole in your car just above the gas tank. There is a install guide floating around somewhere. If you actually drop the tank you are in for a biotch of a time. It only took me a few hours to go through the top.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
