Fuel pressure regulator.
Old Oct 24, 2003 | 03:46 PM
supercharged87's Avatar
What size allen wrench do I need to take it off? 4mm seems too loose and 5mm seems to big, is there a 4.5? I didn't find a standard that fit either. Also anyone have any tips on getting it out to make it any easier?
Old Oct 24, 2003 | 03:56 PM
BUBBA's Avatar
Get some fuel rail removers?
Old Oct 24, 2003 | 03:59 PM
Are you talking about the single screw that holds the fuel pressure regulator to the back of the fuel rail? If so, it is a Torx-27
Old Oct 24, 2003 | 04:09 PM
Thats the screw I'm talking about. Also I have the fuel line tools, but I don't have the right torx bit, I guess I'll go get one now. Thaknks for the help.
Old Oct 24, 2003 | 04:19 PM
I don't have a T-27, but a T-30 seems to fit.
Old Oct 24, 2003 | 04:20 PM
Butcher!
And I bet you use a T-50 for the seat belt bolts instead of a T-47!!!
Old Oct 24, 2003 | 04:32 PM
I got the bolt out, do you have to take 2 bolts out? Also, how do you get the regulator out of the rail, I'm really having trouble being that there's absolutely no room and I can't see what I'm doing.
Old Oct 24, 2003 | 04:38 PM
NOMAD's Avatar
Originally posted by Injuneer
Butcher!
Actually. I had to use an angle grinder on Heather's car. Go be sick !!
You will also need to remove the torx bit that hold both fuel lines together before they connect to the regulator
-Shannon
Old Oct 24, 2003 | 04:50 PM
What size torx bit is that? 27? I can't get the 27 into that little area to see if it even fits, let alone loosen it?
Old Oct 24, 2003 | 06:29 PM
Butcher!
I am so ashamed.
Old Oct 24, 2003 | 08:57 PM
anaik's Avatar
Are you using a screw driver handle torx bit? Get one that fits on a 1/4" ratchet.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
