fuel pressure question
Old Apr 24, 2009 | 01:56 PM
Camaro350z28's Avatar
just to test fuel pressure and to see a leak, i hooked up the gauge and turned key to on, let it prime, then off. gauge held at about 42-44.. how long should it hold this? thanks
Old Apr 25, 2009 | 04:10 AM
mtperformance's Avatar
A few min. or so, but its more important that it shots up there as soon as you turn the key on.
Old Apr 25, 2009 | 08:18 AM
LearJet's Avatar
Not true. It going up when you turn the key on only tells you the pump works. It has to hold pressure as well. If it doesn't then either one or more of your injectors are leaking and no good or your FPR is leaking and no good. Either one of those conditions will cause a poor running engine.
Old Apr 25, 2009 | 11:37 AM
The other possibility is a faulty check valve in the fuel pump. That will make starting hard, but will not affect the way the engine runs.
Old Apr 25, 2009 | 02:10 PM
well it was my FPR, it leaked like crazy when i took the vacuum line off it. changed it out and no more hard starts. thanks guys
Old Apr 25, 2009 | 04:15 PM
ok guys a little more to the equation... my fuel pressure went down to 36 at idle after new FPR... and i took it to drags last night and it cuts out, i couldnt get a good run in. was cutting out everywhere, could only give part throttle.
it doesnt dump fuel pressure on WOT but it never reaches 40 psi, sound like a crappy FPR and could be my issue?
Old Apr 25, 2009 | 07:56 PM
PWR SHFT's Avatar
Sounds like a dying fuel pump.
DirtyDaveW
Dec 1, 2016 05:37 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
dansam
Jul 20, 2002 01:10 PM
