fuel pressure
Old Dec 12, 2010 | 04:26 PM
Bails098's Avatar
fuel pressure
What fuel pressure should i run at. i have 36lb injectors and a walbro pump not sure if more info is needed.
Old Dec 12, 2010 | 06:09 PM
Re: fuel pressure
There is no reason to depart from the stock fuel pressure. 43.5psi, with the vacuum line disconnected. GM accepts anything in the range of 41-47psi. Stock regulator will work fine in that application.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
