fuel pressure
Old Sep 3, 2007 | 08:22 PM
lt1chevelle's Avatar
fuel pressure
what should my fuel pressure be set at on my motor. has le2 heads, gm 847 cam, 1.6 rockers,52mm throttle body. long tube headers, and 37lbs injectors
Old Sep 4, 2007 | 10:48 AM
anyone? i know there are a bunch of smart ppl out there help me out
Old Sep 4, 2007 | 11:50 AM
White96Z28's Avatar
Ideally, you'll leave it at stock fuel pressure. That's what your injectors are rated at. If you change the FP, you may have a hard time getting it tuned.
Old Sep 4, 2007 | 12:01 PM
BUBBA's Avatar
Stock is about 43-45 with vac line off and about 8 less with vac line on.
Old Sep 4, 2007 | 06:20 PM
What pressure did you tell your tuner it was set at? He needed to know that to put the correct injector flow constant in the tune. If you didn't tell him anything about the fuel pressure, he would have assumed its at 43.5psi (no vacuum).
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
